Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to see inside python variables?
3 REPLIES 3
eric
596 Views, 3 Replies
Heres the 'default' hello app
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
So, simple question, theres app and ui, I know nothing about whats 'inside' them, how can I see all the members values inside them?
If I print(ui) I get garbage....<adsk.core.UserInterface; proxy of <Swig Object of type 'adsk::core::Ptr< adsk::core::UserInterface > *' at 0x0000029F4008D0C0> >
To say this output is unhelpful is being overly generous....
So, again, how exactly can I see all the exposed public member variables of ui?  or app?
3 REPLIES 3
marshaltu
in reply to: eric
If you use Spyder which embedded in Fusion 360 to write Python codes, you can probably see code hint when you type and detailed information in Object Inspector.
In addition, you should also be able to get information from our help http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-A92A4B10-3781-4925-94C6-47DA85A4F65A .
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
kevin
in reply to: marshaltu
Just use Visual Studio Community for free w/ Python & C++ so your covered both ways
You also get the added benefits of syncing your profile to cloud
Also Versioning with Team Services since Fusioin 360 Cloud doesn't sync scripts and they are hidden in weird folders to manage
https://www.visualstudio.com/vs/features/python/
JeromeBriot
in reply to: eric
use dir (Built-in Functions) instead of print:
dir(ui)
['__class__', '__del__', '__delattr__', '__deref__', '__dict__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattr__', '__getattribute__', '__gt__', '__hash__', '__init__', '__le__', '__lt__', '__module__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '__swig_destroy__', '__swig_getmethods__', '__swig_setmethods__', '__weakref__', '_get_activeCommand', '_get_activeSelections', '_get_activeWorkspace', '_get_allToolbarPanels', '_get_commandCreated', '_get_commandDefinitions', '_get_commandStarting', '_get_commandTerminated', '_get_isValid', '_get_markingMenuDisplaying', '_get_objectType', '_get_palettes', '_get_toolbars', '_get_workspaceActivated', '_get_workspaceDeactivated', '_get_workspacePreActivate', '_get_workspacePreDeactivate', '_get_workspaces', '_s', 'activeCommand', 'activeSelections', 'activeWorkspace', 'allToolbarPanels', 'cast', 'classType', 'commandCreated', 'commandDefinitions', 'commandStarting', 'commandTerminated', 'createFileDialog', 'createFolderDialog', 'createProgressDialog', 'inputBox', 'isValid', 'markingMenuDisplaying', 'messageBox', 'objectType', 'palettes', 'selectEntity', 'terminateActiveCommand', 'this', 'toolbarPanelsByProductType', 'toolbars', 'workspaceActivated', 'workspaceDeactivated', 'workspacePreActivate', 'workspacePreDeactivate', 'workspaces', 'workspacesByProductType']
And, to me, one of the most important thing when you start to use a new API is its documentation. See UserInterface Object
