Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to remove coincident constrain between two connect line?
2 REPLIES 2
gpq
491 Views, 2 Replies
Hello, I need to remove the coincident constraint between the ends of two draw sketchlines to be able to move independently. Can someone tell me how I can do?
Thanks in advance.
2 REPLIES 2
marshaltu
in reply to: gpq
Unfortunately I didn't find way to delete the kind of "coincident" constraint. By API, you have to delete one of the lines and redraw it with new sketch point to avoid auto coincident constriant.
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
gpq
in reply to: marshaltu
I have split the two intersect line in two segment , one short near at intersection point with other line. and delete this two short segment. Then I move the end of lines on original intersection point. In this way i have remove the coincident constraint.
Thanks for the help.
