Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to plane cut a mesh in API?
4 REPLIES 4
sl3117
292 Views, 4 Replies
Hi guys,
I want to perform plane cut action on a surface mesh. But I can't seem to find any API example on how to do this. Please, could someone help with a script example?
Many thanks.
Tags (3)
4 REPLIES 4
BrianEkins
in reply to: sl3117
The Mesh workspace functionality, which is still in preview, is not supported at all by the API.  You do have access to mesh bodies and the mesh information but there's no functionality for cutting sections or manipulating the mesh in any way.
Brian Ekins
sl3117
in reply to: BrianEkins
Ar I see, what a pity. But thank you Brian.
Any idea when the mesh functionality would be available in API? And is it possible to move (translate and/or rotate) mesh body around through API?
y.a.o.elshebani2
in reply to: sl3117
Any update since this post, is it possible to have plane cut a mesh body using the API. is there a method created or such that allows implement this command of plane cut
