Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to pass in a variable to a function under a condition
2 REPLIES 2
Six1Seven1
243 Views, 2 Replies
Sorry for all the posts. I have run into a problem. This stems back to my novice programming experience... My question is, how do I pass in an argument to a function only sometimes, only when a condition is true. Here is an example...
#call the function----------------------------
if checkbox == True:
    Function1(x, y, z)
else:
    Function1(x,y)
#define the function-----------------------
def Function1(x,y,z)       <----- Problem! variable z is only present when checkbox is TRUE.
Thus, i get an error. How do i define the function to only pass in the variable 'Z' when the checkbox is true? Sorry, I am still inexperienced in programming.
Thanks!
2 REPLIES 2
ekinsb
in reply to: Six1Seven1
Python supports optional arguments in a function.  For your function
def Function1(x, y, z):
You can make the last argument optional by defining a default value for it.  If you don't provide a value when calling the function the default value will be used.  The first example below will set z to zero.
def Function1(x, y, z=0):
If you need to know if the value was assigned by the caller or is the default you could use something else because in the example above, zero would be a valid value to use.  The example below uses None and then you could check for that in the function to see if a value was provided or not.
def Function1(x, y, z=None):
In both cases the function would be called using:
Function1(23, 3.6)
or
Function1(21, 34.6, 1.2)
Brian Ekins
Mod the Machine blog
Six1Seven1
in reply to: ekinsb
Brian, that worked great.
Thank you very much
