Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to get the list of appearances used by a body
1 REPLY 1
grakoczy
250 Views, 1 Reply
Is there fast way of getting appearances list or just count for a body?
I can loop over faces and then check appearance but if body has a lot of faces it takes bit long.
Maybe there is some other, fast way of checking how many appearances are used by the object?
1 REPLY 1
ekinsb
in reply to: grakoczy
This is an area where we need to improve.  Currently the only way to get all of the appearances that apply to a body is to do what you're already doing and iterate over each of the faces.
Brian Ekins
Mod the Machine blog
