Announcements
How to find the world coordinants of a point
Hello, I want to translate an occurrence object to match its origin to another point (sketch or construction point) but I don't know how to find the world co-ordinates of the point.
Any sample code? Many thanks
ekinsb
There are three different objects that represent a point; construction point, sketch point, and a vertex on a surface or solid model.
The ConstructionPoint object has a "geometry" property that returns a Point3D object which is a wrapper for the coordinates of a point.
The BRepVertex object also has a "geometry" property that returns a Point3D object.
The SketchPoint object also has a "geometry" property but in this case the coordinate returned is not what you want.  A sketch point is defined in sketch space, not model space, and the coordinate returned by the "geometry" property is in sketch space.  However, the SketchPoint object has a worldGeometry property which returns a Point3D object in world space.
Below is some code that demonstrates repositioning a selected occurrence to a selected point.
def moveOccurrenceToPoint():
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # Have the occurrence selected.
        occSel = ui.selectEntity('Select an occurrence', 'Occurrences')
        occ = adsk.fusion.Occurrence.cast(occSel.entity)
        if not occ:
            ui.messageBox('An occurrence must be selected.')
        # Have the point selected.
        pointSel = ui.selectEntity('Select a point', 'Vertices, SketchPoints, ConstructionPoints')
        pnt = pointSel.entity
        if not pnt:
            ui.messageBox('A point must be selected.')
        # Get the point geometry.
        coord = adsk.core.Point3D.cast(None)
        if type(pnt) is adsk.fusion.ConstructionPoint or type(pnt) is adsk.fusion.BRepVertex:
            coord = pnt.geometry
        elif type(pnt) is adsk.fusion.SketchPoint:
            coord = pnt.worldGeometry
        # Reposition the occurrence.
        occMatrix = occ.transform
        occMatrix.translation = coord.asVector()
        occ.transform = occMatrix
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
Mod the Machine blog
Thanks for the help.
Follow-up question: How do I translate an occurrence so that its origin will match to an arbitrary point on a Fitted Spline curve?
In other words, I need to find/compute at run time any point's worldGeometry on a spline curve.
Given the spline curve is parametrically defined, there must be a mathematical way to do this. But I am not smart enough to find the solution yet.
Any help much appreciated!
marcinszydlowski.1984
Hello. This is probably outdated but for those who still search a solution there's simple way to calculate this.
You only need to transform point by matrix of sketch which this point belongs to:
# Definition of point in sketch space (2D, but Z coordinate can be also set)
samplePoint = adsk.core.Point3D.create(-2, 3, 1)
# Find its world coordinates
transformedPoint = samplePoint.copy()
transformedPoint.transformBy(sampleSketch.transform)
