Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to find mass and cost of a Part/Model?
9 REPLIES 9
Message 1 of 10
ph0en1x01
507 Views, 9 Replies
Suppose I created a 3D model using an API and assigned it material XYZ. After modifying its dimensions multiple times using the GUI, I now want to determine its mass and associated cost, preferably in an Excel file. Can this be achieved using the API?
If yes, please provide a universal script that can run on any 3D Model just by copy pasting it into the script.
This link contains chassis code which has 9 bodies:
https://github.com/purushottamnawale/cad-customization-of-ev-chassis/blob/main/Chassis.py
Tags (2)
Labels (1)
  • API
9 REPLIES 9
Message 2 of 10
BrianEkins
in reply to: ph0en1x01
You can get the volume and mass from the BRepBody and the Component object. You can't get the cost because Fusion does not know that. You might be able to combine the volume with some external material information to calculate a cost, but there are other factors to consider, such as the manufacturing process. For example, if you're 3D printing the model, the volume of a body may not reflect the actual volume of material used depending on the type of infill you use.
Brian Ekins
Message 3 of 10
ph0en1x01
Thank you for your response. Would it be possible for you to provide me with a sample script?
My goal is to find the mass of all the bodies as shown in the image.
Message 4 of 10
kandennti
Hi @ph0en1x01 .
It can be obtained with the physicalProperties property.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        occ: fusion.Occurrence = root.occurrences[-1]
        show_physicalProperties(occ)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def show_physicalProperties(
    occ: fusion.Occurrence,
    props: fusion.PhysicalProperties = occ.physicalProperties
    origin, _, _, _ = occ.transform2.getAsCoordinateSystem()
    infos = [
        f'Mass \t\t{props.mass}',
        f'Volume \t\t{props.volume}',
        f'Density \t\t{props.density}',
        f'Area \t\t{props.area}',
        f'World X,Y,Z \t\t{origin.asArray()}',
        f'CenterOfMass \t{props.centerOfMass.asArray()}',
    ui: core.UserInterface = app.userInterface
    ui.messageBox('\n'.join(infos))
Message 5 of 10
ph0en1x01
in reply to: kandennti
It gives an error.
raise IndexError("The index (%d) is out of range." % i)
IndexError: The index (-1) is out of range.
Message 6 of 10
kandennti
@ph0en1x01 .
I think it's because I ran it with data that has no occurrence in the root component.
If you don't know what that error means, you may have a lot of trouble in the future.
Message 7 of 10
ph0en1x01
Can you modify the same code, so that it can run for any 3D Model, just by copy pasting it into the script.
Message 8 of 10
kandennti
@ph0en1x01 .
What is this "3D Model" you speak of?
Body? Components? Ocurrence?
Message 9 of 10
ph0en1x01
Message 10 of 10
kandennti
@ph0en1x01 .
Select any of the body, occurrence or root components.
import traceback
def run(context):
    try:
        msg: str = 'Select Entity'
        selFilter: str = 'Bodies,Occurrences,RootComponents'
        sel: core.Selection = selectEnt(msg, selFilter)
        if not sel:
            return
        show_physicalProperties(sel.entity)
        a=1
    except:
        if ui:
    entity: core.Base,
    if not hasattr(entity, 'physicalProperties'):
        return
    props: fusion.PhysicalProperties = entity.physicalProperties
    if hasattr(entity, 'transform2'):
        origin, _, _, _ = entity.transform2.getAsCoordinateSystem()
        worldXYZ = origin.asArray()
    else:
        worldXYZ = '-'
    infos = [
        f'World X,Y,Z \t\t{worldXYZ}',
def selectEnt(
    msg: str,
    filterStr: str
) -> core.Selection:
    try:
        sel = ui.selectEntity(msg, filterStr)
        return sel
    except:
        return None
