Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to export Step file of each part in assembly?
1 REPLY 1
ruban2
120 Views, 1 Reply
Hello
I know method to export step file of assembly. https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-B801DDA8-9A0C-42AD-AC06-F8244CA08D65
But my assembly include many parts.
so I'd like to export step file of each part.
But I don't know method.
1 REPLY 1
kandennti
in reply to: ruban2
@ruban2 .
We don't have enough information to know exactly what you want.
(e.g. depth of the component, you want the output in the position it is positioned at the joint, etc.)
We have created these scripts in anticipation.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
import pathlib
import re
EXPORT_FOLDER = pathlib.Path(r'C:\temp')
def run(context):
    ui = core.UserInterface.cast(None)
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        exportMgr: fusion.ExportManager = des.exportManager
        app.executeTextCommand(u'Transaction.Start export_step')
        set_all_lightbulb(False)
        # export root component
        root.isBodiesFolderLightBulbOn = True
        path = str(EXPORT_FOLDER / get_export_file_name(f'{root.name}') )
        stpOptions: fusion.STEPExportOptions = exportMgr.createSTEPExportOptions(
            path,
            root
        exportMgr.execute(stpOptions)
        root.isBodiesFolderLightBulbOn = False
        # export occurrence
        for occ in root.occurrences:
            occ.isLightBulbOn = True
            path = str(EXPORT_FOLDER / get_export_file_name(f'{occ.name}') )
            stpOptions = exportMgr.createSTEPExportOptions(path, root)
            occ.isLightBulbOn = False
        app.executeTextCommand(u'Transaction.Abort')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def get_export_file_name(fileName: str) -> str:
    return re.sub(r'[\\|/|:|?|.|"|<|>|\|]', '_', fileName)
def set_all_lightbulb(isLight: bool) -> None:
    root.isBodiesFolderLightBulbOn = isLight
    occ: fusion.Occurrence = None
    for occ in root.allOccurrences:
        occ.isLightBulbOn = isLight
If it is different from what you want, please attach as simple and specific f3d/f3z files as possible.
