Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to export hundreds of individual parts/bodies from an assembly to STEP?
3 REPLIES 3
ruban2
132 Views, 3 Replies
As the title said, it's possible to export as a step file, hundred of individial parts/bodies from an assembly? Is this function possible? If not, is there any workaround instead of exporting as a new part one by one?
3 REPLIES 3
BrianEkins
in reply to: ruban2
Can you explain exactly what you want? How is "exporting a part from an assembly" different than "exporting as a new part one by one"?
Brian Ekins
ruban2
in reply to: BrianEkins
I don't want new document and need each step for part.
I read https://forums.autodesk.com/t5/fusion-360-design-validate/how-to-save-hundreds-of-individual-parts-b...  but I cannot find solution.
BrianEkins
in reply to: ruban2
I'm sorry, but I still don't understand what you want to do. Can you provide a simple example assembly and then a detailed description of what you expect as the output?
Brian Ekins
