Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to execute script without aborting current command
1 REPLY 1
ponomarevcs
105 Views, 1 Reply
Can I execute python script without aborting execution of current command?. For example I have simple script which toggle between wire frame and shaded display mode assigned on the hotkey. In «normal» mode all work great, but when I trying to execute script while I'm using fillet command (for example), script cancel this (fillet) command.
1 REPLY 1
kandennti
in reply to: ponomarevcs
Hi @ponomarevcs -San.
Unfortunately, it is basically impossible to execute other commands while a command is being executed.
This is described in the "Using a Custom Event" section of this document.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-F9FD4A6D-C59F-4176-9003-CE04F7558CCC
