I want to draw Hexagon, & follow step:
1. draw line
2. Copy line
3. translate line by line length
4. rotate by 60 deg
1. draw line
2. Copy line
4. rotate by 60 deg
Hi @nkc.mech .
Why don't you calculate the vertex coordinates of the polygon and draw a line between the two points?
#Fusion360API Python Script
import adsk.core, adsk.fusion, traceback
import math
# Circumscribed circle center XY - unit Cm
_center = [1.0, 2.0]
# Circumscribed circle radius - unit Cm
_radius = 5.0
# Vertex count
_vertex_count = 6
# Vertex start angle - unit deg
_ang = 30
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
des = adsk.fusion.Design.cast(app.activeProduct)
root = des.rootComponent
# get Vertexs
pnts = getVertexPoints()
# sketch
skt = root.sketches.add(root.xYConstructionPlane)
# draw Polyline
drawPolyline(skt, pnts)
# finish
ui.messageBox('done')
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def drawPolyline(
skt :adsk.fusion.Sketch,
pnts :list):
count = len(pnts)
pnts.append(pnts[0])
lines = skt.sketchCurves.sketchLines
skt.isComputeDeferred = True
[lines.addByTwoPoints(pnts[i], pnts[i + 1]) for i in range(count)]
skt.isComputeDeferred = False
def getVertexPoints() -> adsk.core.Point3D:
global _center, _radius, _vertex_count, _ang
rad = math.radians(_ang)
unit_rad = math.pi * 2 / _vertex_count
rads = [rad + (unit_rad * idx) for idx in range(1, _vertex_count + 1)]
pnt3D = adsk.core.Point3D
pnts = [pnt3D.create(math.cos(rad) * _radius, math.sin(rad) * _radius, 0)
for rad in rads]
targetPnt = pnt3D.create(_center[0], _center[1], 0)
vec = pnt3D.create(0,0,0).vectorTo(targetPnt)
[pnt.translateBy(vec) for pnt in pnts]
return pnts
