Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to distinguish between different UI flows which result in a document save?
2 REPLIES 2
scottmoyse
178 Views, 2 Replies
Does anyone have any idea how I could figure out if the users has triggered a save via doc/app closing vs using the Save button?
The document events fire in this order documentSaving > documentSaved > documentClosing > documentClosed.
If they were documentClosing >  documentSaving > documentSaved > documentClosed then I could easily catch the scenario.
I've tried checking the sender property on the document event object and the application event object, but the only time a Save specific ID appears is the first time a design is saved... and ONLY when using the Save button (which is kind of weird).
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
2 REPLIES 2
BrianEkins
in reply to: scottmoyse
I don't believe there is a way to know why the save is happening.  I agree that the event order you gave would seem more logical.  Sometimes there are reasons internally for returning events in a certain order, but I don't know if that's the case here.
Brian Ekins
scottmoyse
in reply to: BrianEkins
Ok thanks
Kind Regards
Scott Moyse
Manufacturing Technical Specialist Autodesk Expert Elite
P: +64 9 302 4028 M: +64 21 055 7775
scott.m@cadpro.co.nz
CADPRO Systems Ltd
Auckland - 527b Rosebank Road, Avondale Auckland
Christchurch - Unit 3, Kendal Avenue, Burnside
New Zealand
Scott Moyse
