Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to disable design history capture
2 REPLIES 2
lc752
837 Views, 2 Replies
Is it possible to turn design history off through python instead of using the GUI every time I open a new document. I turn it off to improve performance when undertaking interative tasks. When testing scripts over and over again, it's quite frustrating to keep turning it off. I can't find any information about this anywhere.
Lachlan
2 REPLIES 2
ekinsb
in reply to: lc752
That setting is a bit hard to find.  You can set it using the Design.designType property.  The code below should do it.
des.designType = adsk.fusion.DirectDesignType
Brian Ekins
Mod the Machine blog
lc752
in reply to: ekinsb
Ah yep, very nice. Just added DesignTypes in there and it worked. Thanks a bunch 🙂
design.designType = adsk.fusion.DesignTypes.DirectDesignType
