How to create threaded hole feature
jsormaz
jsormaz
I am trying to create a custom threaded hole feature. Here is what I have so far.
It successfully creates the hole feature, but I can't figure out the API to add a thread to the hole. In general ThreadFeature doesn't seem very well documented.
I get an Exception at the last line below:
def command_created(args: adsk.core.CommandCreatedEventArgs):
    inputs = args.command.commandInputs
    inputs.addSelectionInput("point_selection", "Select Points", "Select points")
    point_selection: adsk.core.SelectionCommandInput = inputs.itemById(
        "point_selection"
    point_selection.addSelectionFilter("SketchPoints")
    point_selection.setSelectionLimits(1, 0)
    futil.add_handler(
        args.command.execute, command_execute, local_handlers=local_handlers
def command_execute(args: adsk.core.CommandEventArgs):
        "point_selection"
    product = app.activeProduct
    design = adsk.fusion.Design.cast(product)
    rootComp = design.rootComponent
    holeFeatures = rootComp.features.holeFeatures
    holeInput = holeFeatures.createCounterboreInput(
        adsk.core.ValueInput.createByString("8.526 mm"),
        adsk.core.ValueInput.createByString("16 mm"),
        adsk.core.ValueInput.createByString("6 mm"),
    holeInput.setDistanceExtent(
        adsk.core.ValueInput.createByString("28 mm"),
    pointCollection = adsk.core.ObjectCollection.create()
    for p in range(point_selection.selectionCount):
        pointCollection.add(point_selection.selection(p).entity)
    holeInput.setPositionBySketchPoints(pointCollection)
    holeFeature = holeFeatures.add(holeInput)
    # All above is working
    threadFeatures = rootComp.features.threadFeatures
    threadType = "ISO Metric profile"
    threadClass = "6H"
    threadDesignation = "M10x1.5"
    holeFaces = adsk.core.ObjectCollection.create()
    for h in range(holeFeature.sideFaces.count):
        holeFaces.add(holeFeature.sideFaces.item(h))
    if holeFaces.count > 0:
        threadInfo = threadFeatures.createThreadInfo(
            True, threadType, threadDesignation, threadClass
        threadInput = threadFeatures.createInput(holeFaces, threadInfo)
        threadInput.isModeled = False
        threadFeature = threadFeatures.add(threadInput)#This line raises an Exception
# RuntimeError: 2 : InternalValidationError : Xl::Utils::getObjectPath(item.get(), facePath, nullptr, contextPath)
FWIW, i'm trying to make the following counterbored threaded hole for Lang quick-point studs
And this is the end result I would like:
Instagram:
@sonsofsormaz
BrianEkins
Unfortunately, you can't create a thread as part of a hole feature. In the early days of Fusion, you had to add a thread feature to a hole to create a hole with a thread. The hole API hasn't been updated since the hole feature was enhanced. Hopefully, it's coming soon.
The current workaround is to create a separate thread feature.
Brian Ekins
john.kirchner
I think I got your script to run successfully on a quick test file I set up - is there any chance you could share an f3d file where you are getting this error?
jsormaz
@BrianEkins thanks, at least good to know I'm not crazy. Is it not still possible to add a separate thread feature though?
@john.kirchner See attached.
Just run the command, select the 4 points in 'Sketch2' and you should get the error.
Instagram:
@sonsofsormaz
