I am trying to create a sketch by adding points and lines by API. The intention is to let the 3 lines below share a point at the blue joint. It seems when a new line is added, new end points are always created separately. Is it possible to use an existing point to create a new line without duplicating the point?
Shoudong Xu
Autodesk Moldflow Meshing
Shoudong.Xu@autodesk.com
