Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to create an offset plane at angle?
2 REPLIES 2
ph0en1x01
195 Views, 2 Replies
I want to create an offset plane to yz plane at an angle to z axis (or some angle with yz plane) on a point marked by red arrow.
I want a sample code for this.
How to achieve this?
Tags (1)
Labels (1)
  • API
2 REPLIES 2
kandennti
in reply to: ph0en1x01
Hi @ph0en1x01 .
I don't know what kind of plane it is, so can you provide me with an f3d file created with the GUI?
Jorge_Jaramillo
@ph0en1x01 , over which axis do you want it to be rotated?
Notice that if you rotate it over an axis other than Y, the offset-ed plane wont be parallel to the XZ plane.
