Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to create an elliptical arc?
3 REPLIES 3
billoverman
2753 Views, 3 Replies
I'm trying to create a series of connected elliptical arcs.
SketchEllipticalArcs would seem a natural place to start. However unlike SketchCircles, SketchLines, etc. SketchEllipticalArcs provides only read-only properties; that is, there are no "add..." methods on SketchEllipticalArcs.
The only way I've found so far, is to create an Ellipse (with SketchEllipses.add) and then use SketchEllipse.trim/split to try to get the proper arc segment.
I think I could get this to work with some work, but it feels extremely kludgy.
Is there a more elegant solution?
Bill
3 REPLIES 3
ekinsb
in reply to: billoverman
Unfortunately, what you've found is currently the only way to do it.  This is the same as in the user-interface, although I hope to support it in the API in the future.
Brian Ekins
Mod the Machine blog
peter_goodman
in reply to: ekinsb
Hi, is this still the case, no way to create an elliptical arc other than creating an ellipse and trimming it with two lines?
Pete.
BrianEkins
in reply to: peter_goodman
Still no change.
Brian Ekins
