Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to create a "Manual NC" operation using the API?
4 REPLIES 4
jan_weidner
179 Views, 4 Replies
The the GUI, one can create manual NC options, like so: Is this possible from the API as well?
4 REPLIES 4
I don't know if it will be available sometime.
While it isn't, a customization to the post-processor could help you.
Jorge Jaramillo
Software Engineer
kandennti
in reply to: jan_weidner
Hi @jan_weidner -San.
How about creating a "Manual NC" template in advance and importing it?
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.cam as cam
import pathlib
THIS_DIR = pathlib.Path(__file__).resolve().parent
TEMPLATE_PATH = str(THIS_DIR / "Manual_NC_Test.f3dhsm-template")
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        # get CAM
        camObj: cam.CAM = app.activeProduct
        # create template from file
        template: cam.CAMTemplate = cam.CAMTemplate.createFromFile(
            str(TEMPLATE_PATH)
        # get setup
        setup: cam.Setup = camObj.setups[0]
        # import template
        setup.createFromCAMTemplate(template)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Attached is a script.
jan_weidner
Ok, thanks! Using the template solution, is there a way to insert a manual nc in the setup after some already existing operations?
kandennti
@jan_weidner -San.
If you do a createFromCAMTemplate for the desired setup, it will be added last.
Conversely, it is not possible to import a template at an arbitrary position, nor is it currently possible to change the order of operations.
