Announcements
How to create a 3D-Sketch along a iso-line ?
maurizio_manzi
maurizio_manzi
I need a 3D-Sketch along a iso line.
I get the iso line and a reference to the sketches, but how can I "add" the iso line to a new sketch ?
It is possible ? If not, how can I linearize (with tolerance) the iso line, so that I can add many lines over point-3d to the sketch ?
Best regards
Maurizio Manzi
The script:
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context😞
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        ws: adsk.core.Workspace = ui.workspaces.itemById('FusionSolidEnvironment') # Referenz ws to design-Workspace
        if ws:
            ws.activate() # Activate design-Workspace
        design = adsk.fusion.Design.cast(app.activeProduct) # CAST - Design Document
        if not design:
            ui.messageBox("Keine Konstruktion / No design document found")
            return
        # Loop around all solids in root.bRepBodies
        root = design.rootComponent # Tree-root-directory
        for solid in root.bRepBodies:
            face = ui.selectEntity('Select a Face', 'Faces').entity
            isocurve = face.geometry.evaluator.getIsoCurve(.5,False)
            sketches = root.sketches # Get reference to root
            sketch = sketches.add(root.xYConstructionPlane) # Add new sketch
            # How to add 3D-Sketch along the isoline ?
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
kandennti
Hi @maurizio_manzi -San.
Iso Lines can be obtained by using the SurfaceEvaluator object.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-31dad9b2-ee1d-4216-8100-09ea44f9967a
The following sample draws the Iso Line of the selected surface in a new sketch.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        msg: str = 'Select Face'
        selFilter: str = 'Faces'
        sel: core.Selection = select_ent(msg, selFilter)
        if not sel:
            return
        create_iso_curves(sel.entity)
        ui.messageBox("Done")
    except:
        if ui:
def create_iso_curves(
    face: fusion.BRepFace,
    count: int = 10,
) -> fusion.Sketch:
    # Evaluator
    eva: core.SurfaceEvaluator = face.evaluator
    parametricRange: core.BoundingBox2D = eva.parametricRange()
    # U Iso Curves
    unitU = (parametricRange.maxPoint.x -
             parametricRange.minPoint.x) / (count + 1)
    uList = [parametricRange.minPoint.x +
             unitU * idx for idx in range(1, count + 1)]
    crvs = []
    [crvs.extend(list(eva.getIsoCurve(prm, True))) for prm in uList]
    # V Iso Curves
    unitV = (parametricRange.maxPoint.y -
             parametricRange.minPoint.y) / (count + 1)
    vList = [parametricRange.minPoint.y +
             unitV * idx for idx in range(1, count + 1)]
    [crvs.extend(list(eva.getIsoCurve(prm, False))) for prm in vList]
    # Draw Sketch
    comp: fusion.Component = face.body.parentComponent
    skt: fusion.Sketch = comp.sketches.add(
        comp.xYConstructionPlane
    splines: fusion.SketchFixedSplines = skt.sketchCurves.sketchFixedSplines
    for crv in crvs:
        if hasattr(crv, "asNurbsCurve"):
            crv = crv.asNurbsCurve()
        splines.addByNurbsCurve(crv)
    return skt
def select_ent(
    msg: str,
    filter: str
) -> core.Selection:
    try:
        ui: core.UserInterface = app.userInterface
        sel = ui.selectEntity(msg, filter)
        return sel
    except:
        return None
maurizio_manzi
thank you very much
