Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to change to "Design" ?
2 REPLIES 2
maurizio_manzi
89 Views, 2 Replies
it's possible to change in the actual document  over a script for example from "Machining" to "Design" ?
The following code only works, if actual document is set to "Design":
import adsk.core, adsk.fusion, adsk.cam, traceback, os
def run(context😞
    ui = None
    try:
        app =       adsk.core.Application.get()
        ui  =       app.userInterface
        design =    app.activeProduct
        exportMgr = design.exportManager
        docName =   app.activeDocument.name
        ui.messageBox('Export an FeatureCAM')
        # path: = os.getenv('TMP') + "\FusionToFC"
        path = r"C:\temp\FusionToFC"
        if not os.path.exists(path😞
          os.mkdir(path)
        #igesOptions = exportMgr.createIGESExportOptions(path + "/" + docName + ".igs")
        #res = exportMgr.execute(igesOptions)
        stepOptions  = exportMgr.createSTEPExportOptions(path + "/" + docName + ".stp")
        res = exportMgr.execute(stepOptions)
        #satOptions = exportMgr.createSATExportOptions(path + "/" + docName + ".sat")
        #res = exportMgr.execute(satOptions)
        #smtOptions = exportMgr.createSMTExportOptions(path + "/" + docName + ".smt")
        #res = exportMgr.execute(smtOptions)
        #fusionArchivevOptions = exportMgr.createFusionArchiveExportOptions(path + "/" + docName + ".f3d")
        #res = exportMgr.execute(fusionArchivevOptions)
        ui.messageBox('Export erfolgreich')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Best regards
Maurizio
2 REPLIES 2
kandennti
in reply to: maurizio_manzi
Hi @maurizio_manzi .
Workspaces.itemById method is used to retrieve and activate Workspaces.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-018cbb0d-90ab-4f48-98cb-3428126f7d27
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ws: adsk.core.Workspace = ui.workspaces.itemById(
            'FusionSolidEnvironment'
        if ws:
            ws.activate()
    except:
        if ui:
Thank you very much
