Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to add password field to command input
2 REPLIES 2
VitautTryputsin
239 Views, 2 Replies
Hello. It need create authentication form or add password to command input. Are there any solutions for this?
2 REPLIES 2
ekinsb
in reply to: VitautTryputsin
You can use a StringValueCommand input and set its isPassword property to True.  This will hide the text being entered and only show dots.
http://help.autodesk.com/view/NINVFUS/ENU/?guid=GUID-278a9eec-e3c4-4488-a0c0-3e926fecaaaa
Brian Ekins
Mod the Machine blog
VitautTryputsin
in reply to: ekinsb
Thank you
