Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to add notes to an operation using the API?
2 REPLIES 2
jan_weidner
116 Views, 2 Replies
In the UI, notes can be added to operations, like so:
How to do this using the API? Is it possible?
2 REPLIES 2
Hi @jan_weidner
It is possible to add notes to the operation here is the documentation
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-00CFA823-DD15-4C9E-A631-A30815CB41CA
Boopathi Sivakumar
Senior Technology Consultant
Thanks works! (I tried it before asking and it didn't, probably I messed something up.)
