Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to access Scripts and Add-ins in Fusion 360 in 2022
1 REPLY 1
codyoebel
210 Views, 1 Reply
 Screen shot below ! First go to preferences , API, checkbox developer check-box.
Hit Shift-S to bring up the mysteriously hidden, cannot find any place all so none-existent scripts and add-ins menu !
I had allot of problems locating this feature as old videos showing how to access the scripts and addin's were from 2015 , and the feature didn't seem to exist on the UI on my Student Version of F360.  So I hope this post helps others.
1 REPLY 1
BrianEkins
in reply to: codyoebel
I assume you're talking about the change made when Fusion changed the UI to have tabs. The "Scripts and Add-Ins" command was moved then and can be seen in the first image in this help topic.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-9701BBA7-EC0E-4016-A9C8-964AA4838954
Brian Ekins
