Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How is the image2surface addin installed on fusion 360 usinG a mac?
2 REPLIES 2
wn002
140 Views, 2 Replies
Would like to use but can't seem to install
2 REPLIES 2
hanskellner
in reply to: wn002
I'm assuming you are asking about my add-in that's found here:
hanskellner/Fusion360Image2Surface: Image2Surface Add-In for Autodesk Fusion 360 (github.com)
The README provides a link to install instructions as well as additional notes on installation.  The install help link is duplicated here:
How to install an add-in or script in Fusion 360 (autodesk.com)
Look for the section on manual installs.
One other option, others have suggested, is to use this for installing from Github (where the add-in is hosted):
Install scripts or addins from GitHub | Fusion 360 | Autodesk App Store
Hans Kellner
Senior Manager, Principal Engineer
wn002
in reply to: hanskellner
Thank you, installed and tested, I will try working with the artwork soon
Wade
