Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How does one use a Batch file to Open Fusion 360, Run few dll files in sequence?
2 REPLIES 2
tperam
325 Views, 2 Replies
How does one use a Batch file to Open Fusion 360, Run few dll files in sequence one after the other created in Visual Studio C++, Then Close Fusion 360.
Can I pass parameters from the batch file into Visual Studio C++?
Thurai.
Labels (1)
2 REPLIES 2
PinRudolf
in reply to: tperam
Hi, I'm not sure if this fits your needs:
Use a batch file to start fusion and create a setup-sheet. On the start of fusion you could get some add-ins to run that would read out the setup-sheet and can than call the appropriate dll's?
Using the setup sheet you should be able to pass parameters ass well.
tperam
in reply to: PinRudolf
Hi  PinRudolf,
                       Thanks for your response.
I will try your steps and see how it goes.
Thurai
