I am a hobby woodworker and build mostly furniture. I have become fairly efficient with Fusion 360 for my furniture design, but I want to be able to automate some of the things I do, such as joinery. I work in the medical field and have no formal training in programming or CAD, but I have done some simple command line programming using BASIC and .BAT files. I studied some basic Python tutorials to get a rudimentary grasp on the language, then went through Brian Ekins' videos about how the object tree works and how the API handles code. I then perused the User Manual and Reference manual for the API. While I understand the concepts in the manuals, I struggle with making them work.
I start with all this to simply say I am a total noob and need major hand-holding, but I have tried to do my homework. I found my question asked before, but the answer was simply "Modify the Name property of the Sketch object." I have no idea how do do that. When I look up "name" under "sketches" in the manual, it says the follwoing, but I don't know how to insert this into my code to get it to work.
# Get the value of the property.
propertyValue = sketch_var.name
# Set the value of the property.
sketch_var.name = propertyValue
To try and figure it out, I am going through the Autodesk Design Academy Lab about making a part for a 3D printer. The first lab is simply to create a sketch and draw some circles (code below). The code works just fine, but the created sketches are just called Sketch1, Sketch2, etc. In this example, how would I give a different name to the newly created sketch ( or for that matter, any newly created body, component, etc.)?
import adsk.core, adsk.fusion, traceback
def run(context):
ui = None
try:
# Define the radius variables for circle1 and circle2
radiusCircle1 = 2
radiusCircle2 = 0.156
# Get the User Interface, used for outputting the message box to the user
app = adsk.core.Application.get()
ui = app.userInterface
# Get the Root Component of the active design
design = app.activeProduct
rootComp = adsk.fusion.Component.cast(design.rootComponent)
# Create sketch 1 on the xy plane.
# First access the sketches collection of the root component
sketches = rootComp.sketches
# Get the xy construction plane from the root component
xyPlane = rootComp.xYConstructionPlane
# Add sketch 1 to the sketch collection using the xy plane
sketch = sketches.add(xyPlane)
# Draw a circle in the sketch.
# Access the sketchcurves and sketch circles collections within sketch 1
circles = sketch.sketchCurves.sketchCircles
# Add a circle to the sketch circles collection by using addByCenterRadius.
# The needed parameters are the center points and radius.
circle1 = circles.addByCenterRadius(adsk.core.Point3D.create(0, 0, 0), radiusCircle1)
# Create sketch 2 on the xy plane.
# Add sketch 2 to the same sketch collection using the same xy plane
sketch2 = sketches.add(xyPlane)
circles2 = sketch2.sketchCurves.sketchCircles
# To create the origin of the second circle on the first circle,
# use the radius of the first circle as the x coordinate when creating the 3Dpoint
circle2 = circles2.addByCenterRadius(adsk.core.Point3D.create(radiusCircle1, 0, 0), radiusCircle2)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Thank you in advance for your help.
