Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How do I use sketch pallet?
2 REPLIES 2
obatake5TC3R
280 Views, 2 Replies
Hi Fusion360 support.
I would like to use the sketch pallet for sketch mode.
And I want to know how to add sketch palette icons.
Is there a sample code somewhere?
2 REPLIES 2
goyals
in reply to: obatake5TC3R
If I understood correctly you might be looking for sample code to add a new command. http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-3922697A-7BF1-4799-9A5B-C8539DF57051. You can find much more samples here http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-A92A4B10-3781-4925-94C6-47DA85A4F65A.
Feel free to reach out to us if you need more inputs.
Shyam Goyal
Shyam Goyal
Sr. Software Dev. Manager
obatake5TC3R
in reply to: goyals
Hi.
I would like to sketch pallet on sketch mode by C++.
I could not find samples for using sketch pellet dialog box.
I would like to create Fusion 360's original ”sketch-> line" command. Therefore, I want to know the display of the sketch palette and the event.
