Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How do I select point on a body like you can when you create a joint?
2 REPLIES 2
adonno
848 Views, 2 Replies
I would like to have a selection object in my script's input dialog that would allow me to select a point on an existing body in a similar way to how the regular UI allows you to do that when creating a joint. Example
2 REPLIES 2
marshaltu
in reply to: adonno
Unfortunately it is not normal selection behaviour in Joint command and so there was no API for expose it. You may have to customize selection by yourself if you want same behaviour. The selection event should be one you can start with.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-3044adfb-f8b9-46ba-bb26-1b6316757537
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
adonno
in reply to: marshaltu
OK, thanks. I had sort-of come to that conclusion myself. Thanks for confirming.
