Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How do I move / rotate the mesh?
4 REPLIES 4
shutov441-vuz
867 Views, 4 Replies
I have a task. I need to rotate and move imported stl model, i do it like this:
dlg = ui.createFileDialog()
dlg.title = 'Open STL File'
dlg.filter = 'Model (*.stl);;All Files (*.*)'
if dlg.showOpen() != adsk.core.DialogResults.DialogOK :
   return
filename = dlg.filename
ModelStl = root.meshBodies
ModelStl.add(filename, adsk.fusion.MeshUnits.CentimeterMeshUnit)
and then i should to rotate and move this model. I found this topic
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/bug-move-feature-is-broken/m-p/9223668
it works fine, but i need to do it inside one script. I tried to move the mesh like a default object, but it throws errors.
something like this...
rotateModel = adsk.core.Matrix3D.create()
rotateModel.setToRotation(math.pi / 2.0, adsk.core.Vector3D.create(1,0,0), adsk.core.Point3D.create(0,0,0))
moveFeats = root.features.moveFeatures
moveFeatureInput = moveFeats.createInput(ModelStl, rotateModel)
moveFeats.add(moveFeatureInput)
Labels (1)
  • API
4 REPLIES 4
BrianEkins
in reply to: shutov441-vuz
Unfortunately, the API doesn't currently support moving a mesh body.  There have been significant changes/enhancements made to the move command and the API has not yet been updated to support these.  Hopefully, not too far in the future.
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
Hi @shutov441-vuz,
like @BrianEkins said, there is no method in the fusion API to move/rotate a MeshBody.
But you can use the trimesh-library to create a non-fusion-mesh, move/transform this and add this transformed mesh back to fusion.
You'll need the trimesh-lib, as well as the numpy-lib.
You can use a class I created recently:
import numpy as np
import trimesh as tri
import adsk.core, adsk.fusion
class MyTrimesh():
    """Class handles the trimesh functionality """
    def __init__(self):
        self.trimesh = tri.base.Trimesh()
    def create_from_fMesh(self, fmesh:adsk.fusion.MeshBody):
        """creates a Trimesh from a Fusion-MeshBody"""
            vertices=np.reshape(fmesh.mesh.nodeCoordinatesAsDouble,(-1,3)),
            faces=np.reshape(fmesh.mesh.triangleNodeIndices,(-1,3)),
            vertex_normals=np.reshape(fmesh.mesh.normalVectorsAsDouble, (-1,3)))
        self.trimesh.merge_vertices(merge_tex=True, merge_norm=True)
    def create_from_bRep(self, brep:adsk.fusion.BRepBody):
        """creates a Trimesh from a bRepBody"""
        mgr = brep.meshManager.createMeshCalculator()
        mgr.setQuality(adsk.fusion.TriangleMeshQualityOptions.LowQualityTriangleMesh)
        meshbody = mgr.calculate()
            vertices=np.reshape(meshbody.nodeCoordinatesAsDouble, (-1, 3)),
            faces=np.reshape(meshbody.nodeIndices, (-1, 3)),
            vertex_normals=np.reshape(meshbody.normalVectorsAsDouble, (-1, 3)))
        self.trimesh.merge_vertices(merge_tex=True,merge_norm=True)
    def transform(self, matrix:adsk.core.Matrix3D):
        """executes a transformation on the trimeshBody"""
        self.trimesh.apply_transform(np.reshape(matrix,(-1,3)))
    def add_to_component(self, comp:adsk.fusion.Component) -> adsk.fusion.MeshBody:
        """adds the Trimesh to the components meshBodies and returns the created fMeshBody"""
        nodeCoordinates = self.trimesh.vertices.flatten().tolist()
        nodeIndices = self.trimesh.faces.flatten().tolist()
        normalVectors = self.trimesh.vertex_normals.flatten().tolist()
        meshBody = comp.meshBodies.addByTriangleMeshData(nodeCoordinates, nodeIndices, normalVectors, nodeIndices)
        return meshBody
    def deleteMe(self):
        """sets the trimesh-value to None"""
        self.trimesh = None
So you can add this to your code:
# if you added the class as separate file to your folder
from . import MyTrimesh as tri
#root = adsk.core.Application.get().activeProduct.rootComponent
mesh0 = ModelStl[0]   # or any other body
trimesh = tri.MyTrimesh()   # creates Instance
trimesh.create_from_fMesh(mesh0)   # add meshbody to trimesh
trimesh.transform(rotateModel)   # move/rotate trimesh
trimesh.add_to_component(root)   # add rotated meshbody to root.meshBodies
del trimesh
I hope this works for you, I´m using this class and it works fine for me. The only issue is, the Meshbody will added to the root.meshBodies, no matter what component you put in to the add_to_component-function.
I made a misstake in the transform-function
instead of
it should be
        self.trimesh.apply_transform(np.reshape(matrix.asArray(),(-1,4)))
shutov441-vuz
Hi @Anonymous, thank you for your solution. I solved this problem. All I needed to do was move and rotate the model. I did it like this.
def move_mesh_model(vector3D, mesh_item):
    design.designType = adsk.fusion.DesignTypes.DirectDesignType
    temp_mesh_models.add(mesh_models.item(mesh_item))
    transform = adsk.core.Matrix3D.create()
    transform.translation = vector3D
    moveFeatureInput = moveFeats.createInput(temp_mesh_models, transform)
    temp_mesh_models.clear()
All you had to do was switch the design mode.
