Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How do I create a "null" BRepBody to use in CombineFeatures->createInput?
3 REPLIES 3
julian.tilbury
335 Views, 3 Replies
I would like use the C++ API to create a new component by joining existing components.
I think I need:-
Ptr<CombineFeatures> CF = /* get from component */
Ptr<CombineFeaturesInput> CFI = CF->createInput ( TargetBody, ToolBodies );
CFI->isNewComponent(true);
CFI->operation(JoinFeatureOperation);
CF->add(CFI);
where ToolBodies is a Ptr<ObjectCollection> of my existing components,
and TargetBody is a Ptr<BRepBody>, which, as I'm creating a new
component, is presumably a blank/null/new object. How do I create it?
3 REPLIES 3
I used the first component of the ToolBodies as the TargetBody and the code
appears to execute but doesn't create a new combined body.
Can anyone give me an API example of joining two components to form
a new component please?
BrianEkins
in reply to: julian.tilbury
Below is the run function from a C++ script that demonstrates this.
extern "C" XI_EXPORT bool run(const char* context)
	app = Application::get();
	if (!app)
		return false;
	ui = app->userInterface();
	if (!ui)
		return false;
	Ptr<Design> des = app->activeProduct();
	Ptr<Component> root = des->rootComponent();
	Ptr<Selection> select = ui->selectEntity("Select the target body.", "Bodies");
	Ptr<BRepBody> targetBody = select->entity();
	adsk::doEvents();
	select = ui->selectEntity("Select the tool body.", "Bodies");
	Ptr<BRepBody> toolBody = select->entity();
	Ptr<ObjectCollection> tools = adsk::core::ObjectCollection::create();
	tools->add(toolBody);
	Ptr<CombineFeatures> combines = root->features()->combineFeatures();
	Ptr<CombineFeatureInput> combineInput = combines->createInput(targetBody, tools);
	combineInput->isKeepToolBodies(true);
	combineInput->isNewComponent(true);
	combineInput->operation(adsk::fusion::FeatureOperations::CutFeatureOperation);
	Ptr<CombineFeature> combine = combines->add(combineInput);
Brian Ekins
julian.tilbury
in reply to: BrianEkins
Thank you Brian.
I was using an ObjectCollection of Components, not an ObjectCollection of
BRepBodies for the ToolBodies.
