Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How do I Add a Folder to a cam setup?
1 REPLY 1
enervino
61 Views, 1 Reply
1 REPLY 1
enervino
in reply to: enervino
so this feature is not very intuitively designed but here is a sample hidden somewhere:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-995d634e-a8ef-4f2b-a826-1d32171f4998
        #################### steep and shallow operations ####################
        # Create folder for finishing operations that require Machining Extension
        operationInput = setup.operations.createInput('folder')
        operationInput.displayName = 'Machining Extension Required'
        folder: adsk.cam.CAMFolder = setup.operations.add(operationInput)
