Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How do I access the components of the Manufacturing Models?
1 REPLY 1
salvador
118 Views, 1 Reply
I successfully obtained the CAM object
    cam = adsk.cam.CAM.cast(product)
I found that cam.designRootOccurrence.component.allOccurrences gives me access to
the components as seen in the Design workspace but I want to gain access
to the components with further operation applied to them in the Manufacture
workspace.
1 REPLY 1
BrianEkins
in reply to: salvador
API support for CAM is currently lacking and the use of the Design model in CAM is one of the big holes. This has caused problems for me in the past with projects I've worked on so I hope it is addressed soon.
By the way, the designRootOccurrence property is not officially supported and I'm guessing will disappear at some point in the future once the supported interface becomes available.
Brian Ekins
