Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How create Polygon (API)
5 REPLIES 5
raterWBBQB
705 Views, 5 Replies
How create Polygon (API) C++
5 REPLIES 5
HughesTooling
in reply to: raterWBBQB
Have you looked at the samples in the help?
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-98e163be-fd07-11e4-9c39-3417ebd3d5be
Mark
Mark Hughes
Owner, Hughes Tooling
raterWBBQB
in reply to: HughesTooling
Exist function for hexagon?
marshaltu
Unfortunately there is no API to create Polygon directly as what users can do in UI. However you can probably make use of existing API(e.g. SketchLines/SketchLine) to work it around. It may need some math calculation to get the start/end points of every line.
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
Hello! Can you please tell me, is there still no possibility of building polygons in the API?
Nothing has changed in this area.
Brian Ekins
