Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How compile AddIn with MFC for used another PC
4 REPLIES 4
-pezi-
336 Views, 4 Replies
Hi
I wrote my own add-in for Fusion 360 that uses MFC (inspired NativeUI by Adam Nagy, Autodesk). It works fine on my computer, but when I install it on another computer it doesn't run. I know that advising them without being able to see the source code is almost impossible. Despite this, can you try to advise me where I am going wrong? Missing some link? Project compiler settings? ... I used MS Visual Studio 2019 latest version on Windows 10.
4 REPLIES 4
BrianEkins
in reply to: -pezi-
It sounds like your dll has some dependencies that are not on the other computer.  I would try installing the Microsoft VC++ Redistributable on the other computer and see if that solves the problem.  If it does, you can include the redistributable with your installer for your add-in.
Brian Ekins
-pezi-
in reply to: BrianEkins
thanks for your advice, but installing MS VC++ Redistributable doesn't solve my issue. I tried building the project with the setting of Use MFC in a Static Library instead of Use MFC in a Shared DLL. With this settings addIn is possible to load to Fusion360, but when the MFC dlgWindow should load, I got error like this "File: f:\\dd\vctools\vc7libs\ship\atlmfc\src\mfc\appcore.cpp. Line: 196. **line 196". I can't solve this problem for now.
BrianEkins
in reply to: -pezi-
I don't know what the problem is.  I don't think it has anything to do with Fusion and is a general question about deploying a program that uses MFC.  I would suggest posting a question on StackOverflow.
Brian Ekins
-pezi-
I agree that it won't be a problem with Fusion360 and thank you for the direction anyway.
