How can I script the process of generating g-code/toolpath in Fusion 360 for an STL file?
abhijeet-singh
abhijeet-singh
I want to generate the g-code for a 3d printable STL file using Fusion API in Python. The process should start with
* Import the STL
* Make CAM setups
* Generate g-code/toolpath
* Simulate toolpath
* Hide printer bed, layout grid, and set camera parameters(like orientation and position)
* Take screenshots at specified layers
BrianEkins
The API for the Manufacturing functionality in Fusion is currently very limited. What you've described is not currently possible to automate.
Brian Ekins
abhijeet-singh
Hi Brian,
Thanks for the reply. I'm glad to hear from you!
I understand that it is difficult to obtain the results I'm looking for. I'm making quite a progress though. I just want to know how can I click on a button using the script, as I'm trying to import machine info in the setup. Please refer to the screenshot below for clarification:
Best Regards,
Abhijeet Singh
