Announcements
How can I get informed about joint value changes? (Python)
Is it possible to get informed by an event about joint value changes, such as for example the slideValue of the SliderJointMotion?
Or would it be more suitable to poll the current value in a background thread?
EDIT:
I  just saw that someone actually tried something similar: https://forums.autodesk.com/t5/fusion-360-api-and-scripts/real-time-robotic-control/td-p/6377717
But I don't necessarily need real-time updates of the value when driving the joints. Although this would be a neat feature.
marshaltu
Unfortunately there is no event to watch joint value changes. It would be doable to poll the current value in background. Theoretically some API calls would not work in worker thread. Please try custom event if you run into the issue.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-F9FD4A6D-C59F-4176-9003-CE04F7558CCC
Marshal
Marshal Tu
Fusion Developer
Okay, so then polling is the way to go forward. Do you know if Fusion 360 supports running normal Python threads in the background? This would be useful for communication with the outside world, else I will need to build some kind of connectionless communication interface to an external application (whatever that means under Windows).
marshaltu
Yes, I think so. You can probably refer to the following sample:
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-85edd118-c2a4-11e6-b401-3417ebc87622
Marshal
Marshal Tu
Fusion Developer
Excellent, this works like a charm. I have a basic demo sending the current joint position to Machinekit up and running, more should follow soon. In theory, this will enable programming machines directly via Fusion 360.
