How can I draw an arc with a constant radius with python?
Hi, fusion 360 community
I'm a beginner at fusion360.
I want to draw an arc with a constant radius by a python script.
So I wrote this script to draw an arc with a central angle of 90 degrees and a radius of 1 cm on XZ plane. However, the results both of them were different as the picture below shows.
What should I do?
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        pi = 3.xxx-xxxxxxxx
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        root = design.rootComponent
        sketch = root.sketches.add(root.xZConstructionPlane)
        arcs = sketch.sketchCurves.sketchArcs
        arcs.addByCenterStartSweep(adsk.core.Point3D.create(0,0,0),adsk.core.Point3D.create(1,0,1),pi/2)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
goyals
I think you need to specify the start point adsk.core.Point3D.create(1,1,0) if you want to draw the sketch as shown in attached picture.
Shyam Goyal
Sr. Software Dev. Manager
