Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How can create loft by some edges.
2 REPLIES 2
ho-kou
89 Views, 2 Replies
hi, veryone.
I want to use some edges(Picture1) to create a loft (Picture2).
But use my code can't do it.
Thank your for your help.
Here is my code:
        colChnagedEdge_1 = adsk.core.ObjectCollection.create()
        colChnagedEdge_1.add(edge1)
        colChnagedEdge_1.add(edge2)
        colChnagedEdge_2 = adsk.core.ObjectCollection.create()
        colChnagedEdge_2.add(edge3)
        loftFeats = _rootComp.features.loftFeatures
        loftInput = loftFeats.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        loftSectionsObj = loftInput.loftSections
        path1 = adsk.fusion.Path.create(colChnagedEdge_1, adsk.fusion.ChainedCurveOptions.connectedChainedCurves)
        section1 = loftInput.loftSections.add(path1)
        section1.setTangentEndCondition(adsk.core.ValueInput.createByReal(1.0))
        path2 = adsk.fusion.Path.create(colChnagedEdge_2, adsk.fusion.ChainedCurveOptions.connectedChainedCurves)
        section2 = loftInput.loftSections.add(path2)
        section2.setTangentEndCondition(adsk.core.ValueInput.createByReal(1.0))
        loftInput.isSolid = True
        loftInput.isClosed = False
        loftInput.isTangentEdgesMerged = False
        loftFeats.add(loftInput)
2 REPLIES 2
BrianEkins
in reply to: ho-kou
I tested your code, and it worked for me. Are you sure your edge1, edge2, and edge3 variables are being set correctly? Here's my full code. I select the edges first and then run the script. The edges are retrieved in the same order they're selected, so the two connected edges must be selected first, and then the third individual edge.
def LoftSample():
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        _rootComp = des.rootComponent
        edge1 = ui.activeSelections[0].entity
        edge2 = ui.activeSelections[1].entity
        edge3 = ui.activeSelections[2].entity
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
ho-kou
in reply to: ho-kou
Thank you very much for your help.
