Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How can create a button beside ok button.
1 REPLY 1
ho-kou
110 Views, 1 Reply
Hi, every one.
I want to create button beside ok button like the picture.
who know how can do it.
Thank you for your help.
1 REPLY 1
j4n.vokurka
in reply to: ho-kou
you can't do that as far as I'm aware. You can hide OK button, change text of OK or Cancel button, set help file if you have a reason for it but you cannot add another control into the footer. Only table command input has some of this functionality but you probably wouldn't like that solution.
I think you will have to stick to putting controls into the main dialog area. Sorry to bring bad news.
