help automating task
Can someone help me with and script to do the following steps:
I have a folder with dxf files
within that folder for every dxf file
-Start a new file
-import dxf to xy plane
-extrude simple profile (maybe click to select) to a standard lenght (100mm)
-save the file to the same name as the DXF file  "dxfname_3D"
-create a drawing using an existing template template
-save drawing file as "dxfname_drw"
-repeat until all files have been done.
Many thanks
Huba
Replies (15)
kandennti
Hi @Anonymous .
Fusion360API does not support the drawing.
Therefore, the following two are impossible.
OK. THanks for the reply.
Then just the firts part create 3d models from a batch of dxf with the same name???
kandennti
Because I do not understand English, I may not understand.
I think it is possible to import a DXF file, extrude it and save it with the same name.
Thanks for that.
Any chance you can share a solution??
Thanks for that.
kandennti
Business is busy and can not be started.
I will make it if you give me time.
Sure. Whenever you have time it will be good. Thanks
kandennti
I'm sorry that I was late.
It may lack functionality, but it imports multiple DXF files, performs an extrusion,
and saves them under the same name as the DXF file.
The save destination is in the "importDXF" project.
(The account to which the "importDXF" project is logged in
If it does not exist, create it. )
#Fusion360API Python script
#Description-importDXF & Extend test
import adsk.core, adsk.fusion, traceback
from pathlib import Path
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
_prj = adsk.core.DataProject.cast(None)
# saving project name
_PROJECT_NAME = 'importDxf'
# Extend Distance(unit Cm)
_EXTENDDISTANCE = 10.0
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        # select dxf files
        paths = getFilePaths()
        if len(paths) < 1: return
        # create document
        global _EXTENDDISTANCE
        results = [initFusionDoc(path, _EXTENDDISTANCE) for path in paths]
        # finish
        _ui.messageBox('\n'.join(results))
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def setDataProject():
    global _app, _PROJECT_NAME, _prj
    for prj in _app.data.dataProjects:
        if prj.name == _PROJECT_NAME:
            _prj = prj
            return
    _prj = _app.data.dataProjects.add(_PROJECT_NAME)
def initFusionDoc(
    path :str,
    length :float
    ) -> str:
    pathObj = Path(path)
    adsk.doEvents()
    try:
        global _app
        typeFuDoc = adsk.core.DocumentTypes.FusionDesignDocumentType
        doc = _app.documents.add(typeFuDoc)
        des = adsk.fusion.Design.cast(_app.activeProduct)
        root = des.rootComponent
        # dxf import
        iptMng = _app.importManager
        dxfOpt = iptMng.createDXF2DImportOptions(path, root.xZConstructionPlane)
        dxfOpt.isViewFit = False
        skts = iptMng.importToTarget2(dxfOpt, root)
        # profile
        profs = adsk.core.ObjectCollection.create()
        for skt in skts:
            for prof in skt.profiles:
                profs.add(prof)
        # pad
        exts = root.features.extrudeFeatures
        newBodyOpe = adsk.fusion.FeatureOperations.NewBodyFeatureOperation
        dist = adsk.core.ValueInput.createByReal(length)
        exts.addSimple(profs, dist, newBodyOpe)
        # save
        global _prj
        if not _prj:
            setDataProject()
        doc.saveAs(pathObj.stem, _prj.rootFolder, '', '')
        return pathObj.stem + ' : OK'
    except:
        return pathObj.stem + ' : NG'
def getFilePaths() -> list:
    global _ui
    dlog :adsk.core.FileDialog = _ui.createFileDialog()
    dlog.isMultiSelectEnabled = True
    dlog.title = "Select Open DXF Files"
    dlog.filter = 'DXF files (*.dxf)'
    dlog.filterIndex = 0
    res = dlog.showOpen()
    if res == adsk.core.DialogResults.DialogOK:
        return dlog.filenames
    else:
        return []
Thank you very much for this much appreciated.
damien.huvelle
Hi, just found your reply in this post when searching about batch DXF importer.
Is there a way to modify your script to make him open those DXF in the same file and make them not stacked on each other but spaced from each other ?
With my job (wooden furnitures) I often need to import as many DXF that there is parts, so it would be very helpful.
thanks
kandennti
Hi @damien.huvelle .
After running the script, why not try using the pattern in the GUI?
damien.huvelle
@kandennti
You script open different DXF in seperate files, I would like to open those in the same file (batch importing). I suggested to add that the DXF don't stacks on each other but side by side.
do you think it's possible ? you seems pretty good with scripting (not like me ...)
kandennti
I don't know a good algorithm for doing the placement.
However, by using the bounding box of component and occurrence
I think it is possible to arrange them so that they do not overlap.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-A2DF83DA-A919-446F-A8A9-3684635058E5
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-6E1510A3-3014-4958-8D03-878025C9F093
Of course, I think it is possible to deploy with API.
(I don't have time to work on it now)
kandennti
I was able to secure time, so I repaired it.
An algorithm for optimal placement to avoid duplication I do not know.
Therefore, I simply arrange them side by side.
The process takes a little longer because you have to wait for the data panel to update.
↓The modified script is attached.
damien.huvelle
@kandennti
hello, thanks for you work ! I finally found this on github which is made by tapnair. This is exactly what I was waiting for and I finally found it.
thanks
