Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Hello, how could I make angled letters for extrusion?
7 REPLIES 7
Message 1 of 8
christianwhats1
295 Views, 7 Replies
Preciso fazer letras anguladas para extrusão, alguém tem conhecimento no assunto. obrigado
"I need to make angled letters for extrusion, does anyone have knowledge on the subject. thanks"
Translated by Google
Traduzido por [@clacampos] através do Google Tradutor
Labels (1)
7 REPLIES 7
Message 2 of 8
@Jorge_Jaramillo - this post is being edited to remove PII.
Hi @christianwhats1 ,
In the extrude command you have the TAPER ANGLE like in the following image:
In the API you have ExtrudeFeature.taperAngleOne and ExtrudeFeature.taperAngleTwo properties to set it accordingly.
I hope this could help.
Best regards,
Jorge Jaramillo
Message 3 of 8
Hi Jorge, Thanks for the feedback.
The problem is that the letters in curved drawings, such as B and C, I cannot extrude at an angle (as in the image) only the letters in straight lines in the example of the image that I send you, the extrusion was made only in the letter A. problem I noticed when I made it, was that the top part of your drawing was flat like a lid in the base shape (letter drawing, as I need it), and in my drawing after the extrusion it was triangular, tapering like a peak of a mountain . I used Arial Black font.
In the second image is what I need to do, inverted letters to print the front and edges, and the upper part (which will be the bottom of the letter) open to put the cover. Thanks in advance for the help
Message 4 of 8
If you want it wider on top you might use a positive taper angle. Negative taper angles will make it narrower on top.
With Arial font it worked for me like in the following image:
Maybe you can explode the text (right click on text and choose "Explode Text" option) to lines inside the sketch before extruding it.
You have to play a little bit with combinations between height and taper angle, because not all combinations work.
Jorge Jaramillo
Message 5 of 8
Hello Friends , I made a preview of what I need, the letter is hollow and the bottom is open, so that a lid can be placed later, but this wall that goes down from the top to the bottom, has to have an angle decline, increasing the width of the letter at the bottom. And this whole process will be done in the same way, keeping the same design in the other letters of the text
Message 6 of 8
I believe this is what you are looking for:
The letter is hollow, has a taper angle in the walls and is open in the base.
The max taper angle it allows it to assign in that letter size/height is 8 degrees.
Please find attached F3D file so you can check how I made it.
I hope it could help you.
Jorge Jaramillo
Message 7 of 8
Exactly that, thank you very much. And how would I place the support for the lid on the back after having done the extrusion at an angle?
Message 8 of 8
You can increase the thickness to 2mm, create a new sketch on the bottom face of the body and project that face, then offset internal o external edges to make a center line (1mm distance to each).
That way you have faces which you can extrude to cut 1 or 2mm for the lid, as you did with your example.
Jorge Jaramillo
