Announcements
Having trouble with TemporaryBRepManager.createHelixWire()
I am having trouble getting the createHelixWire to work.
Here is a script that should generate a Helix with:
 Oriented along the Z-axis
 starting at z=0
 pitch 0.2
 turns 10
 diameter 2
 no taper
But it just generates a straight vertical wire. I can't figure out what I am doing wrong.
The Helix Wire in the TemporaryBRepManager sample generates fine so it must be my fault.
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        des = app.activeProduct
        root = des.rootComponent
        bodies = root.bRepBodies
        tbm = adsk.fusion.TemporaryBRepManager.get()
        hw1 = tbm.createHelixWire(
            adsk.core.Point3D.create(0,0,0),
            adsk.core.Vector3D.create(0,0,1),
            adsk.core.Point3D.create(1,0,0),
            0.5,
            10,
            0.5
        bodies.add(hw1)
    except:
        print(traceback.format_exc())
kandennti
Hi @Anonymous .
When using Temporary BRepManager in Parametric mode, bodies.add must be done in the base future.
It will look like this.
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        root :adsk.fusion.Component = des.rootComponent
            0.5,
            10,
            0.5
        if des.designType == adsk.fusion.DesignTypes.ParametricDesignType:
            # Parametric mode
            baseFeatures = root.features.baseFeatures
            baseFeature = baseFeatures.add()
            baseFeature.startEdit()
            bodies.add(hw1, baseFeature)
            baseFeature.finishEdit()
        else:
            # direct mode
            bodies.add(hw1)
    except:
The completed BRepWire Object will not be displayed correctly on the screen except for straight lines.
However, if you use it as the path of the GUI pipe command, you can confirm that you have the correct information.
I made use of this and created this.
https://github.com/kantoku-code/ExportWire
Thank you so much!
Sorry, I forgot to mention that my code only runs in direct modeling mode.
This had me stumped for days, and in the end, it just didn't display correctly.
For some reason, the wire created by the TemporaryBRepManager sample code does display correctly, so I thought it must be something I am doing wrong.
kandennti
When I included it in the sketch, I was able to confirm the correct state.
            # Parametric mode
            wire = bodies.add(hw1, baseFeature)
        else:
            # direct mode
            wire = bodies.add(hw1)
        skt = root.sketches.add(root.xYConstructionPlane)
        skt.include(wire.edges[0])
