Message 1 of 1
[HANG] app.documents.open(dataFile=drawingFile, visible=False)
Hi there,
I've been writing a script to export a bunch of drawing files to PDFs.
When visible is set to TRUE ...documents.open(dataFile=drawingFile, visible=True) all is OK.
But - when visible is set to False - Fusion hangs.
Seems like the drawing file opens (I can see the component browser) - the toolbar is a little whacky - no drawing per se - and Fusion just sits still.
import adsk.core
import adsk.fusion
import adsk.drawing
import traceback
app = None
ui = None
design:adsk.fusion.Design = None
def run(context):
global app, ui, design
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
drawingFiles:adsk.core.DataFiles = getDrawingFiles()
adsk.doEvents()
#outputFolder:adsk.core.DataFolder = getDrawingOutputFolder()
outputDirectory = getDrawingOutputDirectory()
for drawingFile in drawingFiles:
#doc:adsk.core.Document = app.documents.open(drawingFile)
drawingDoc:adsk.drawing.DrawingDocument = app.documents.open(dataFile=drawingFile, visible=True)
#drawingFile.
exportDrawingToPdf(drawingDoc, outputDirectory)
drawingDoc.close(saveChanges=False)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def getDrawingFiles() -> adsk.core.DataFiles:
cloudDialog = ui.createCloudFileDialog()
cloudDialog.title = 'Select drawings to export.'
cloudDialog.isMultiSelectEnabled = True
cloudDialog.filter = 'f2d'
dialogResult = cloudDialog.showOpen()
if dialogResult == adsk.core.DialogResults.DialogOK:
#dataFolder:adsk.core.DataFolder = cloudDialog.dataFolder
dataFiles:adsk.core.DataFiles = cloudDialog.dataFiles
return dataFiles
def getDrawingOutputFolder() -> adsk.core.DataFolder:
cloudDialog.title = 'Select output folder.'
dialogResult = cloudDialog.showSave()
return dataFolder
def getDrawingOutputDirectory():
folderDialog = ui.createFolderDialog()
folderDialog.title = 'Selection output folder.'
dialogResult = folderDialog.showDialog()
foldername = folderDialog.folder
return foldername
else:
return
def exportDrawingToPdf(
drawingDoc:adsk.drawing.DrawingDocument,
outputDir:str
msg = f'{drawingDoc.name}'
app.log(msg)
#msg = f'{outputFolder.name}'
#app.log(msg)
msg = f'{outputDir}'
app.log(msg)
outputFileName = drawingDoc.name
filename = outputDir + '/' + outputFileName + '.pdf'
exportManager:adsk.drawing.DrawingExportManager = drawingDoc.drawing.exportManager
PDFOptions:adsk.drawing.PDFExportOptions = exportManager.createPDFExportOptions(filename)
PDFOptions.filename = filename
PDFOptions.sheetsToExport = adsk.drawing.PDFSheetsExport.AllPDFSheetsExport
PDFOptions.openPDF = False
PDFOptions.useLineWeights = False
exportOK = exportManager.execute(PDFOptions)
return exportOK
Cheers !
Glenn.
