Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Go to next Command Input
1 REPLY 1
robKFEUG
262 Views, 1 Reply
Is there anyway to enable the TAB or ENTER key to move to the next command input?
I have 10 entries and having to click each one after entering data is a pain.
1 REPLY 1
marshaltu
in reply to: robKFEUG
TAB key works to switch among multiple ValueCommandInput/AngleValueCommandInput. You can go to next ValueCommandInput by the key. Unfortunately it doesn't work for other command inputs.
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
