Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Give error vs code while debug (Pyhon)
9 REPLIES 9
Message 1 of 10
kgokhank
607 Views, 9 Replies
Hi
I try to write script in fusion 360 in Python language
I create the script in fusion 360 and click edit my script and vs code opening
I editing my code and click debug button give error VS code
I attached error message
9 REPLIES 9
Message 2 of 10
hpekristiansen
in reply to: kgokhank
Message 3 of 10
Rushikesh.kadam
@kgokhank
One needs to click on Debug in “Scripts and Add-in” dialog of Fusion to debug. Currently, debugging from VS code after clicking on Edit in “Scripts and Add-in” dialog is not supported. However, we will come up with a solution to support it in future.
Thank you for your time.
Rushikesh Kadam
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
Message 4 of 10
Thank you, but I think you wrote to me instead of OP by a misstake.
Message 5 of 10
@hpekristiansen  Thank you for correcting me 🙂
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
Message 6 of 10
kgokhank
in reply to: hpekristiansen
hi @hpekristiansen
thanks for help I tried your idea and partially resolved previously running code does not work now (in Spider Editor).
Is there any change available ?
Message 7 of 10
dewaine50
I absolutely NEED the ability to switch back to the way it was WORKING before with Spyder. All these new changes to Visual Studio has practically ruined workflow for me, and worse is i've been getting errors left and right. Because everything is so new, there are no good search results on how to resolve them. Nothing is familiar. And what's worse is that This author says you can point Fusion to whichever IDE you prefer but provides literally no instruction whatsoever on how to achieve this. Please help, I really need Spyder ASAP.
Message 8 of 10
hpekristiansen
in reply to: dewaine50
I can not help you.
Embrace the development. The  version of spyder used was terrible outdated.
Message 9 of 10
dewaine50
No it wasn't. Everything WORKED. NOTHING in VS is working right now.
Message 10 of 10
hpekristiansen
NO NEED TO YELL AT ME. I did not make the changes, and I do not know enough to help.
The version of spyder used by Fusion was outdated - that is a know fact. Here is a discussion about using a newer version: https://forums.autodesk.com/t5/fusion-360-api-and-scripts/can-we-use-spyder-4/td-p/8462444 - maybe something you can use.
