Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Get Tool Library from Assets CAMTools
3 REPLIES 3
jessemilio463
232 Views, 3 Replies
I want to get Tool Library from Cloud Assets CAMTools, but the last line returns false with no Tool Library URLs
I've probed also with  ToolLibs->childFolderURLs(CloudToolsURL) but no result
Ptr<ToolLibraries> ToolLibs = CamLibMgr->toolLibraries();
Ptr<URL> CloudToolLibrariesURL = ToolLibs->urlByLocation(adsk::cam::LibraryLocations::CloudLibraryLocation);
std::vector<Ptr<URL>> CloudToolLibraryAssetURLS = ToolLibs->childAssetURLs(CloudToolLibrariesURL); if (CloudToolLibraryAssetURLS.size()==0) return false;
Ptr<URL> CloudToolLibsURL = CloudToolLibraryAssetURLS[0]; if (!CloudToolLibsURL) return false;
std::vector<Ptr<URL>> CloudToolLibraryURLS = ToolLibs->childAssetURLs(CloudToolLibsURL); if (CloudToolLibraryURLS.size() == 0) return false;
3 REPLIES 3
std::vector<Ptr<URL>> CloudToolLibraryURLS = ToolLibs->childAssetURLs(CloudToolLibrariesURL)
already contains the URL's of the Tool Libraries in the Asset CAMTools Folder
I've checked it with
Ptr<ToolLibrary> CMIToolLibrary;
string LibPathName;
for each (Ptr<URL> LibURL in CloudToolLibraryURLS)
LibPathName = LibURL->pathName();
if (LibURL->pathName() == "TOOLS-CMI.json")
CMIToolLibrary = ToolLibs->toolLibraryAtURL(LibURL);
Ptr<Tool> Tool0 = CMIToolLibrary->item(0);
Ptr<CAMParameters> pars = Tool0->parameters();
ui->messageBox(pars->itemByName("tool_description")->expression());
jeff.pek
in reply to: jessemilio463
We are looking into this now. I think I'm seeing the same thing you're seeing.
  Jeff
jeff.pek
Actually, this does seem to be working. I think what's happening is that the set of library URLs that you get back is the first cloud library, not the "cloud://" root URL. So, you need to get its parent to be able to get all of them under that root.
Jeff
