Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Get Sketch Plane Using Python
1 REPLY 1
isocam
661 Views, 1 Reply
Can anybody help?
Does anybody know how to get the sketch plane (Front, Top or Right) that a sketch was created on?
I can do this in Inventor but I do not know how to do this in Fusion 360
Many thanks in advance!!!
Darren
1 REPLY 1
kandennti
in reply to: isocam
Hi isocam.
Try it
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        sel = Sel('select sketch','Sketches')
        if sel is None: return
        skt = adsk.fusion.Sketch.cast(sel.entity)
        refplane = skt.referencePlane #This
        if refplane.classType() == 'adsk::fusion::BRepFace':
            msg = '{} face'.format(refplane.body.name)
        else:
            msg = refplane.name
        ui.messageBox('Reference Plane is\n' + msg)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def Sel(msg, selFilter):
    try:
        return ui.selectEntity(msg, selFilter)
    except:
        return None
