Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
get point position relative to Origin
2 REPLIES 2
Brian_Sullivan
569 Views, 2 Replies
To get position of a point relative to the plane it was drawn. I can use
    rootComp.sketches.sketchCurves.sketchLines[index].startSketchPoint.geometry.[x|x|z]
How do I get the numbers relative to the origin.
Like in the GUI, when you click on the point and it shows in the bottom right .
2 REPLIES 2
JesusFreke
in reply to: Brian_Sullivan
Most (all?) Sketch related objects have a worldGeometry property, which gets an object in the world coordinates. In the case of a SketchPoint, it will return a Point3D object relative to the origin.
 rootComp.sketches.sketchCurves.sketchLines[index].startSketchPoint.worldGeometry.[x|x|z]
Brian_Sullivan
in reply to: JesusFreke
That works.
Spent hours chasing rabbits yesterday, trying to find that.
