Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Get pattern from feature
2 REPLIES 2
DWhiteley
213 Views, 2 Replies
In the API, I have selected a feature. How do I find if it is in a pattern and get access to that pattern in order to access the other entities in that pattern?
Thanks in advance,
Dave
2 REPLIES 2
OceanHydroAU
in reply to: DWhiteley
The way I typically answer tricky questions like this myself is as follows:
1. Write code to that lets you select something
2. Put a break-point in after the selection
3. Inside the debug environment, you can then inspect everything about the object you have selected using their excellent IDE.
In your case, I'd select 2 things - one from a pattern, one not - then compare them looking for the difference.
Here's an example 'patyes' is a point from a pattern, 'patno' is not.
You'd have to expand all the tabs to find where they differ, and possibly call methods etc to walk the tree..
DWhiteley
in reply to: OceanHydroAU
Many thanks for your assistance. I’m programming in C++ and debug doesn’t seem to give me the info I need. I assume I need to go over to Python to get better feedback?
