Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Get Part Attributes When Exporting A BOM Using A Python Script
3 REPLIES 3
isocam
178 Views, 3 Replies
Can anybody help?
I can set a Fusion 360 "part attribute" using the following Python script....
def SetPartType(PartType):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
selectedComponent = adsk.fusion.Design.cast(app.activeProduct).rootComponent
compAttributes = selectedComponent.attributes
newAttribute = compAttributes.add('PartAttributes', 'Part: Type', PartType)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
And then, I can read the "part attribute" using the following Python script....
def GetPartType():
ui = None
try:
readAttribute = compAttributes.itemByName('PartAttributes', 'Part: Type')
PartType = readAttribute.value
return PartType
except:
if ui:
How can I get the part attribute when exporting a BOM file using a Python Script?
def traverseAssembly(occurrences, currentLevel, OutputString):
for i in range(0, occurrences.count):
occ: adsk.fusion.Occurrence = occurrences.item(i)
PartNumber = re.split(' v\d+', occ.name)[0]
PartType = ???????
Many thanks in advance!
Darren
3 REPLIES 3
isocam
in reply to: kandennti
kandennti,
I tried the flat pattern script, but nothing seemed to work.
I do not know what the Chinese writing means.
Could you please supply a new script, fully in english?
All I need is to create a "flat pattern" dxf file from a Fusion 360 sheet metal part
The dxf file, for testing purposes, just needs to be saved to the desktop,
Many thanks in advance!!!!
Darren
BrianEkins
in reply to: isocam
Give this a try:
def run(context):
    try:
        flatProduct: adsk.fusion.FlatPatternProduct = app.activeDocument.products.itemByProductType('FlatPatternProductType')
        if flatProduct is None:
            ui.messageBox('No flat pattern exists in the active document.')
            return
        flat = flatProduct.flatPattern
        if flat is None:
            return
        filename = 'C:/Temp/Test.dxf'
        flatExportOptions = flatProduct.exportManager.createDXFFlatPatternExportOptions(filename, flat)
        if flatProduct.exportManager.execute(flatExportOptions):
            ui.messageBox(f'Successfully exported flat pattern to: "{filename}"')
        else:
            ui.messageBox('Flat pattern export failed.')
    except:
        if ui:
Brian Ekins
